How do I determine the SRST feature license on a 2851 router?
rcrumm_2
Level 2
Level 2
I've looked everywhere except where it is.
Randall
dezoconnor
Level 4
Level 4
Hi Randall, if from the command prompt you can type call-manager-fallback then your router is licensed for SRST. A 2851 supports upto 96 phones in SRST mode.
If you do a sh ver and check your IOS version if its 12.4(15)T3 and higher srst is supported.Check the following link :
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps2169/data_sheet_c78-485221.html
Please rate if useful...
I need to know the exact feature license. If you look at the link, which I ssaw yesterday, it says "suports up to 96 phones" but I may not have a license for 96.
If i do a show call-manager-fallback it says max 30 phones. So i think I have a 30 phone license.
I just want to see I have a 30 phone license.
Randall
