How do I mimic a call route
kbeaton
I don't know what this is called, but I believe there's a way to mimic a call route.
I have outbound faxes that are getting a line busy error, but if I call from my phone and the call goes through.
I believe I've seen this done in the past, but don't know what it's called or how to do this.
Any help would be appreciated!
Did you mean CUCM DNA?
https://<<CUCMIP>>/dna
If you mean to simulate a call directly from you VG/CUBE, the command is
csim start <<number>>
Keep in mind that there are some issue to execute that command while in SSH session...so , temporarly enable telnent on your VG/CUBE to test the call simulator but then remember to switch to ssh only once finished
Carlo
Please rate all helpful posts "The more you help the more you learn"
Carlo
CUCM DNA is what I was looking for!
Thanks, I'm going to see what YouTube has so I can learn how to use this tool..
Thanks again
It’s not directly rocket science to use DNA. Recommend that you play around with it, especially since there is no impact in using it. You cannot do any harm by using it.
Response Signature
