11-25-2009 05:43 AM - edited 03-15-2019 08:36 PM
Hi there
I have setup the UC520 for most call processing tasks and one of the things that are pending is voicemail. When I dial 500, the number just beeps 4 times a second.
TPOC-UC520#sh run | be dial-peer voice 2000
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
destination-pattern 500
b2bua
voice-class sip outbound-proxy ipv4:10.1.10.1
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711alaw
no vad
ephone-dn 13 dual-line
number 204 no-reg primary
label 204
description 204
name 204
call-forward noan 500 timeout 10
ephone 27
device-security-mode none
mac-address 001A.4B68.2D14
username "nocadmin" password password
type CIPC
button 1:13
ephone-27[26] Mac:001A.4B68.2D14 TCP socket:[1] activeLine:0 REGISTERED in SCCP ver 15/9
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:10
IP:172.16.1.3 45242 CIPC keepalive 31 max_line 8
button 1: dn 13 number 204 CH1 IDLE CH2 IDLE
Preferred Codec: g711ulaw
Username: nocadmin Password: password
11-25-2009 08:29 AM
Try the following change
destination-pattern 500... (assuming your dial plan is three digits)
11-25-2009 08:36 AM
I take that back, adding the dots won't help.
It would be interesting to see the debug ccsip messages and debug voice dialpeer though
11-25-2009 08:37 AM
b2bua
codec g711alaw
TPOC-UC520#sh run | include destination-pattern 500
TPOC-UC520#
no vad
11-25-2009 08:41 AM
Remove this from the config "voice-class sip outbound-proxy ipv4:10.1.10.1", and I would like to know that you are getting to calling into the voice mail and also how are you doing the calls.
11-25-2009 08:44 AM
Change codec to "codec g711ulaw" instead of g711alaw.
Brandon
11-25-2009 08:45 AM
Strip the config down to this and change the last line from alaw to ulaw. Unless Cisco has recently changed it CUE only runs ulaw
codec g711alaw
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/design/CP_CIPExpress/cipce21.html
11-25-2009 08:50 AM
Cool, I am able to access it now!!!!!!
Which ID and pin is it asking for now?
11-25-2009 08:59 AM
The ones that you configure under the inicial setup the first time that you access the GUI.
