How do I size data circuits to prepare them for CUCM deployment?
JimPatch01
We've deployed CUCM at out main facilities and are preparing to deploy to a variety of smaller, remote sites ranging in size from 5 to 200 phones. I need to know a way to size the data circuits to be able to support the added voice traffic. We do not have QOS configured, and probably will not prior to deployment. I realized that traffic, whether the site is a heavy CCX environment will have an impact, but I really need a "rule of thumb" "10 phones= 5 meg, 100 phones = 10 meg, etc...   Does anyone have a formula?
Thank you.
Jim Patch
Jagpreet Singh
HI Jim,
     When making calls from site to site, we always suggest that the G729 codec be used. You can allocate the BW according to :
http://www.cisco.com/en/US/tech/tk652/tk698/technologies_tech_note09186a0080094ae2.shtml
Jagpreet
Jim,
Depends you technology like MPLS for example. But as a rule of thumb, use 24k/channel for G729 and 80k/channel for G711.
Gert
http://www.cisco.com/go/pdihelpdesk
Please rate helpful posts
There's no thumb rule, you need to do some math based on number of calls and kind of technology you'll be using, protocol, codec, etc
Bandwidth Provisioning
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/srnd/9x/netstruc.html#wp1165070
Voice Codec Bandwidth Calculator
http://tools.cisco.com/Support/VBC/do/CodecCalc1.do
Voice Over IP - Per Call Bandwidth Consumption
http://www.cisco.com/en/US/partner/tech/tk652/tk698/technologies_tech_note09186a0080094ae2.shtml
Bear in mind you also need to configure CAC in CUCM and QoS to make sure RTP/signaling gets the right priority.
java
if this helps, please rate
java
