How do you enable web access from ATA 191's IVR interface?
amoskraus
I would like to use my Cisco ATA 191 with a cloud solution.  I've been able to to get into the IVR and get the IP address (from option 110), but I'm unable to web into that IP address from a workstation that is on the same VLAN.  It seems like web access might be disabled by default. Is there a IVR command that will enable that feature?  If so, please share.
Thank you!
amoskraus
I'm a bit embarrassed to admit. I just realized I have the Cisco On-premises model: ATA191-K9, not the 3rd-party UCaaS model: ATA1919-3PW-K9.  That is why mine wouldn't let me web into it until after it registered with CUCM and the web interface was pretty much view only.
https://www.cisco.com/c/en/us/products/unified-communications/ata-190-series-analog-telephone-adapters/index.html
I referenced this guide to learn the DHCP assigned IP address, but I do not see the an IVR menu option listed that enables web access.  If you see it in this document or know the IVR menu option # for it please let me know what it is, because I'm still not seeing it.
Thank you for your reply.
amoskraus
