12-11-2015 02:06 PM - edited 03-17-2019 05:12 AM
I am using SIP phones in my setup. What is the significance of SIP route patterns? How does it differ from normal route patterns?
Solved! Go to Solution.
12-11-2015 03:59 PM
The fact you use SIP phones is completely irrelevant
A SIP RP routes the domain or IP you configure in it, it will only match the RHS of the URI you dial, besides that, you also configure a partition and a SIP trunk or RGL, have you looked at it in your server?? Or in the CUCM documentation???
12-11-2015 03:59 PM
12-12-2015 07:17 AM
Jaime is correct +5. You would normally not define SIP pattern unless you are doing video integration or CWMS where these are being used.
12-13-2015 02:10 PM
Chris, when you say "video integration", I assume you mean VCS?
12-13-2015 02:23 PM
VCS, Expressway B2B, third party Video URI dialing.
02-02-2016 05:53 AM
hi I wanna achieve this set up and i have all the components but its not quite coming together can you assist?
12-13-2015 06:17 PM
Also for TP Conductor meetings.
