Bookmark
Subscribe
820
How many DLUs are neccesary per 7800 series phones in a CUCM 8.5 platform?
I appreciate your response,
Terry Cheema
Brandon is right (+5) if you don't have the device pack applied they will not show up there.
Diego: Here is the screen shot that shows 7821 will use 2 DLU and 7841 and 7861 will use 3 DLUs on CUCM 8.5 platform.
5 Replies 5
Brandon Pierce
Level 4
Level 4
I'm not sure but I think you would need to contact Cisco to find that out since everything is on ELM/PLM these days.  I know they can down-convert to a PAK file if you needed additional licensing.  But someone else with the phone loads/device pack on their system might want to chime in for a more direct answer.
Terry Cheema
You can check from CUCM. Go to System> Licensing
you should be able to see your license uasage reports as well as how many DLU each phone model would consume.
-Terry
The 7800s won't be on there unless he uploaded the device pack as far as I know.  My 8.6 lab doesn't show them on there since they are relatively new in perspective to 8.5.
Terry Cheema
Thank you so much!!!
