How many simultaneous calls can be made on a CUCM 6.1.4
We have a cluster of five UCM's on a 7835H2 platform. What is the limit of simultaneous calls that the UCM can proccess before it starts to throttle?
Albert
Adam Thompson
Level 4
Level 4
Albert,
According to the data sheet for CUCM 6.x:
Maximum of 100,000 busy-hour call completions (BHCCs) per Cisco Unified Communications Manager server and 250,000 per server cluster (configuration dependent)
A good thing to use would be the Cisco Unified Communications Sizing Tool. It is available at http://tools.cisco.com/cucst
Adam
Please rate if helpful
Adam Thompson
Level 4
Level 4
Albert,
Adam
Hi Adam,
I saw the same numbers in cisco documentation. I wanted to confirm this. I was not able to access the sizing tool you suggested.
Albert
