How to add 8851s to CUCM 9.1.1 with Dev Pack?
I'm running CUCM 9.1.1.10000-11 in VMWare Workstation for my lab, Demo License. I want to use 8851 phones so will need to add the Dev Pack 9.1(2.16147) so they appear as an option to add a phone.  Will I need to upgrade the cluster to 9.1.2 in order install the dev pack?  Or, can I install the dev pack to the existing 9.1.1 version?
5 Replies 5
Aman Soi
you need to do minor upgrade  to 9.1.2
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-8800-series/datasheet-c78-731667.html
regds,
aman
Rob Huffman
Hi there,
You are most correct! You can't install a 9.1.2 device pack on a 9.1.1 CUCM so you would need to upgrade to at least 9.1.2. If you upgraded to the latest 9.1.2 version support for the 8851's would be included already.
http://www.cisco.com/web/software/282074295/136762/cucm-readme-912su6.pdf
Cheers!
Rob
EDIT: +5 to my buddy Aman for his good tips and for his superior typing skills!
Thanks Rob.  Will I need to get an Enhanced User Connect License (UCL) to use the 8851 phone, or will it work with a Demo license?
It will work with demo licence, but when demo licence expires you would need Enhanced license.
(Rate if it helps)
JB
IP phone would work with demo licenses for grace period of 60 days.
After the expiry of same, u need to purchase permanent licenses.
regds,
aman
