How to add 900 to the CLI of incoming international calls where suppliers sends in "+"
cblaney
  I am trying to modify the displayed CLI on my phones for international calls from the SIP provider we are using, they are sending international calls CLI in the format sip:+XXXXXXXXXXX@anonymous.invalid, I'd like to replace the "+" with "900" to allow callback from the missed call directory. I don't believe I can match on the "+" using translation patterns on the router.
I am running a 2900ISR as the gateway and a CM 9.5 platform.
It does match, use the following:
rule 1 /\+\(.*\)/ /900\1/
HTH Regards, Yosh
5 Replies 5
yahsiel2004
Level 7
Level 7
You're using CUCM or CUCME?
HTH Regards, Yosh
You can match on "+" with a translation-rule. How do you have your call routing configured. Could post your configuration?
Yosh
HTH Regards, Yosh
  This is what I normally do on ISDN :-
voice translation-rule 100
 rule 1 /^/ /900/ type international international
 rule 2 /^/ /9/ type national national
 rule 3 /^/ /9/ type unknown unknown
But this being a SIP I am trying :-
 rule 1  /^/ /9/  for in country CLI's
and some rule that swaps "+" for 900, but I was under the impression + is a special character that does not match on a translation pattern ?
HTH Regards, Yosh
cblaney
Hi its a CUCM 9.5.
