How to block a number on jabber.
Faz cisco
Visitor
We are getting multiple calls from outside organization. Some of the calls are showing the numbers and some of the calls are showing the name.
How we can block these numbers on jabber.
b.winter
It's not directly done in Jabber, but in CUCM.
Check out this post with the referenced links:
https://community.cisco.com/t5/unified-communications/block-unknown-number/m-p/3004167
It is not a straight answer to your query, but along with the @b.winter mentioned thread, if you are using expressway in the setup, you may have to look into restricting calls using CPL rules and search rules for all PSTN and anonymous calls. it may not helps you to block coming to your extension but avoid sending calls to PSTN (toll fraud).
you may have to look at restricting the calls both in the call manager and expressway to avoid such calls.
Expressway Blobk ISDN calls
Block anonymous calls in Expressway - External reference.
I assume you are getting the calls over MRA.
Call Policy Rules on Expressway protect against scanners and toll fraud.Read the below Cisco Live Presentation. There are number of Live documents regarding this topic.
https://www.ciscolive.com/c/dam/r/ciscolive/emea/docs/2019/pdf/BRKUCC-2801.pdf
Response Signature
