How to block simulated calls on Voice Gateway?
yousefbustami
In my company, our IPCC system is connected to GSM network through TDM and PRA links destributed over three CISCO voice gateways, I discovered that some hackers are using some call simulation applications to simulate caller IDs and access the IVR.
I tried to block those calls, unforetunately no rule can be applied on the ICM since the call seems to be normal, the only thing that
distinguish fake call from real one is through a GSM parameter called IMSI, but this parameter is not handled in the SIP protocol, as I know, my question is anyway to block calls on VGWs depending on the existance of IMSI, or is there anyway to block such fake calls?
13 Replies 13
islam.kamal
Level 10
Level 10
I hope my answer will help you , i do not have big experience on IPCC
eouter#conf t
router(config)#voice translation-rule 1
router(config-xxx)#rule 1 reject /number/
router(config-xxx)#rule 2 reject /number/
2. Apply the Translation rule to a Translation Profile and give it a name.
(This will be used to apply to the incoming Dial-peers.)
router#conf t
router(config)#voice translation-profile call_block
router(config-xxx)#call-block disconnect-cause incoming call-reject
in this case we named the Translation Profile "call_block"
3. Apply Translation Profile to incoming Dial-peers (only) on each router.
dial-peer voice 1 pots
call-block translation-profile incoming call_block
incoming called-number .T
direct-inward-dial
port 0/0/0:23
Thank you
please rate if this will help and good luck
Thanks Islam,
But how can this rule distinguish if the call is fake or not? I mean call simulator can use a valid number and simulate the call. those rules are just to block a call depending on the caller
That is true , if you have known numbers which you neeed to block. For simulate to ideentify the fake numbers , i can think with you . Please tell me for examplea fake number which you have
thank you
it can be any customer number ... for example, one can use the simulater to make a call with your number Islam, imagine that this problem on your GSM network, and a hacker used this tool and used your number and call your contact center using your own number,
i think for Hackers issues , i think somehing like IPS ,(security device) which can detect soemthing like this
No.
IPS is for data network.
OP has the problem on telephone network, that is different..
You are right , i know that. what i need to say may be there is a security or monitoring tool can detect this which can detect the session of the intruder and disable it.Anyway , i hope that Mr/Yousef get a olution and please share it .
paolo bevilacqua
No, you cannot block calls appers genuine.
zhigangyan
I think asa firewall with a gtp inspection feature maybe can solve this problem.
As answered above already: no.
I am still looking for a way to recognize any parameter can be used, till now I 've found nothing, as you know , SIP protocol has not suciefent  security parameters
Anas Abueideh
Level 9
Level 9
I have just test the below config and it works fine
rule 1 reject /065555555/
voice translation-profile block
  translation calling 1
  call-block translation-profile incoming block
  direct-inward-dial
  port 0/0/0:15
your incoming calls use SIP trunk or PSTN. if it is SIP I think you need to block the signaling ports based on the source IP.
Anas
please rate if it is helpful
  direct-inward-dial
  port 0/0/0:15
Anas
I'm afraid you do not understand the issue, so try again understaing this:
Cannot block calls having an effectlively spoofed calling number
http://en.wikipedia.org/wiki/Caller_ID_spoofing
