06-19-2017 11:52 AM - edited 03-17-2019 10:36 AM
Our version is:
System version: 11.5.1.10000-6
We would like to block 60 numbers in call manager. If someone can help us out that would be great. Thank you.
06-19-2017 12:48 PM
I'll assume you mean incoming calls, if so, this topic has been discussed hundreds of times before in CSC, a quick search will provide you with all the information related to this.
For outbound calls, configure translation patterns and set them to block the calls.
06-20-2017 07:15 AM
Hello, can we do the configuration without impacting the calls or without resetting anything?
06-20-2017 08:41 AM
I depends on your setup...but I recommend you if you're not sure to schedule all changes after hours.
06-19-2017 09:10 PM
Search on google and you would find numerous discussions as per your requirement. Check the below link for reference
https://www.google.co.in/search?site=&source=hp&q=block+numbers+in+cucm&oq=block+numbers+in+cucm&gs_l=psy-ab.3...4105.7551.0.7776.22.12.0.0.0.0.473.1293.3-1j2.3.0....0...1.1.64.psy-ab..19.3.1293.0..0.C4JgGpW3R5I
Abhay
