How to change language on login page of mobility extension on ip phone 79XX
Thiago Gandara
Hi voice team, i configured the extension mobility and works fine, but the customer wants to change the language on ip phone 79XX (login page), how to change the language?
Thanks.
Thiago Gandara
Chris Deren
You need to select the correct user locale on the phone to reflect the language on the phone when logging in. Once logged in the user locale defined on the UDP profile is used.
HTH,
Chris
But the phones are already in the correct language, the only thing that is not in the correct language is when I click services - extension mobility -> login, I want to change that too
Thanks.
