02-20-2013 04:56 AM - edited 03-16-2019 03:49 PM
How can we check the codec used for active call?
Solved! Go to Solution.
02-20-2013 05:11 AM
On 79XX phone you can simply double click the ? mark. On other phones you need to get to the phone details from menu.
You can also browse the IP address of the phone and see it on the active stream, or you are using you can check the GW via show active call commands.
HTH,
Chris
02-20-2013 05:11 AM
HTH,
Chris
02-20-2013 07:01 AM
5 stars to Chris
chrysostomos
02-20-2013 07:21 AM
Thanks Chrysostomos, appreciate it, but where is the 5 stars
Chris
