how to config Lawful Intercept
hcriddick
I have to config Lawful Intercept on 7600, IOS version 12.2(33)SRC6. Every step have be taken by "Cisco 7600 Lawful Intercept Configuration Guide".
Such as:
Router(config)# snmp-server view tapV ciscoTap2MIB included
Router(config)# snmp-server view tapV ciscoIpTapMIB included
Router(config)# snmp-server group tapGrp v3 auth read tapV write tapV notify tapV
Router(config)# snmp-server user ss8user tapGrp v3 auth md5 ********
Router(config)# snmp-server engineID local 1234
Then
Router#show snmp mib
There are:
citapStreamCapabilities
citapStreamInterface
cTap2MediationNewIndex
cTap2MediationDestAddressType
cTpa2MediationDessAddress
and so on
BUT
when I exec snmpwalk from snmp manager, most of LI objects have disappeared.
for example:
>snmpwalk -v 3 -U user -l authNoPriv -a md5 -A ******** 172.10.1.1 1.3.6.1.4.1.9.9.399
SNMPv2-SMI::enterprises.9.9.399.1.1.1.0 = INTEGER:1
SNMPv2-SMI::enterprises.9.9.399.1.1.3.0 = Hex-STRING:A0 00
SNMPv2-SMI::enterprises.9.9.399.1.3.1.0 = INTEGER:2
SNMPv2-SMI::enterprises.9.9.399.1.3.2.0 = INTEGER:100
where is cTap2MediationDestAddressType (1.3.6.1.4.1.9.9.399.1.1.2.1.2)?
Also cTap2MediationDestAddressType can't be set with snmpset.
So, config failed? or these objests should be created? or something?
This is what I came up with so far, if anyone can add to the list, I would appreciate it.
riddick
hcriddick
anyone help?
Did you get any answer to this?
I'm having the same issue...
