NIM-4FXO and dspfarm configuration
Kyle Morrison
I have a new ISR4331 and trying to configure per recommendations from a senior colleague.
Suggested config:
voice-card 0/1
dspfarm
dsp services dspfarm
dsp tdm pooling
However, I do not see any dsp parameters under the voice card.   Do I need a specific feature set to run the DSP's?
spo-rfiridium-vgw2(config)#voice-card 0/1
spo-rfiridium-vgw2(config-voicecard)#?
Voice-card configuration commands:
  codec         Manage codec configuration parameters for voice card
  default       Set a command to its defaults
  exit          Exit from voice card configuration mode
  local-bypass  Enable TDM hairpinning
  no            Negate a command or set its defaults
spo-rfiridium-vgw2#show ver
Cisco IOS XE Software, Version 03.16.04b.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S4b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Mon 17-Oct-16 20:23 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2016 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
spo-rfiridium-vgw2 uptime is 5 days, 6 hours, 37 minutes
Uptime for this control processor is 5 days, 6 hours, 38 minutes
System returned to ROM by reload at 23:18:28 UTC Thu Nov 30 2017
System restarted at 20:43:56 UTC Fri Mar 30 2018
System image file is "bootflash:isr4300-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite                 Suite Current         Type           Suite Next reboot
FoundationSuiteK9     None                  None           None
securityk9
appxk9
AdvUCSuiteK9          None                  None           None
uck9
cme-srst
cube
Technology Package License Information:
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
appxk9           None             None             None
uck9             uck9             Permanent        uck9
securityk9       None             None             None
ipbase           ipbasek9         Permanent        ipbasek9
cisco ISR4331/K9 (1RU) processor with 1648789K/6147K bytes of memory.
Processor board ID FLM2148V134
5 Gigabit Ethernet interfaces
4 Voice FXO interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3125247K bytes of flash memory at bootflash:.
thank you
You cannot configure "dspfarm" for pooling etc. If you need to use a PVDM card for media resources on a ISR-4k, you need to have them on the motherboard. Leftover dsp channels from a NIM T1/E1 can be used as part of media resources but not from a NIM FXO/FXS.
8 Replies 8
Rajan
Hi Kyle,
is the voice card slot correct ? Can you share the output of below commands to check that.
sh diag
sh inv
Also you need to enter "dsp services dspfarm" first followed by "dspfarm" not in the reverse order.
Rajan
Pls rate all helpful posts by clicking the star below
Have you installed DSP on the motherboard or NIM. In 4331, the card should
be installed on the NIM to be used for PSTN
The DSP's are onboard.
https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/datasheet-c78-733646.html
"The FXO, FXS, E/M, and BRI NIMs contain an onboard DSP and don't require the router to have dedicated packet voice DSP module (PVDM) on the motherboard."
spo-rfiridium-vgw2#sho voice dsp
DSP DSP DSPWARE CURR BOOT PAK TX/RX
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABORT PACK COUNT
----------------------------FLEX VOICE CARD 0/1 -----------------------
*DSP VOICE CHANNELS*
CURR STATE : (busy)inuse (b-out)busy out (bpend)busyout pending
LEGEND : (bad)bad (shut)shutdown (dpend)download pending
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABRT PACK COUNT
*DSP SIGNALING CHANNELS*
DM8147 001 01 {flex} 40.2.10 alloc idle 0 0 0/1/0 00 0 10/0
DM8147 001 02 {flex} 40.2.10 alloc idle 0 0 0/1/1 00 0 10/0
DM8147 001 03 {flex} 40.2.10 alloc idle 0 0 0/1/2 00 0 10/0
DM8147 001 04 {flex} 40.2.10 alloc idle 0 0 0/1/3 00 0 10/0
------------------------END OF FLEX VOICE CARD 0/1 ----------------------------
Thats matching what I am trying to say. Open the router and confirm that
you see DSP in the NIM not on the motherboard
Doesn't the output of 'show voice dsp' indicate that the DSP's are on FLEX VOICE CARD 0/1 and not the motherboard?
I'm only slightly familiar with voice configs and hardware, and I've never worked with a NIM-4FXO.
The router is very remote, I'll try to get to it tomorrow.
How about the technology package or suite of IOS? Is that an issue, based on the show ver I posted?
Thank you
You don't need a separate PVDM for FXO cards on the ISR-4k. They are embedded on the card itself and no, you won't be able to see them/replace them like a NIM-T1/E1. AFAIK none of the outputs will show a PVDM on the FXO card.
The PVDM on this FXO cannot be used for anything else.
I'm not looking to replace them. The DSP's are on the NIM-4FXO. I want to configure 'dspfarm' on the voice card in slot 0/1. There are no dsp options under voice-card config. Is there somewhere else to configure this parameter?
