How to Configure CUCM for Connection Between Nodes (through site to site vpn)
monasir
Hi All,
Im trying to find out the best approach to connect
One cucm cluster (with one pub/one sub) with 2 other islands  which also have one subscriber
This needs to be done in a site to site vpn configuration.
Also i need to know what the requirements are for making this all possible.
Latency etc etc
Jaime Valencia
So, are you asking how to do CoW??
Or simply how to configure a SIP trunk between two clusters?
java
if this helps, please rate
VoIP Engineer
You could configure a pair of expressways, and have those islands connect over the internet, without a VPN.
Most companies I've seen have an MPLS circuit between locations.
The other option is to have a site to site vpn between your main site and each island.  You'll be at the mercy of the internet for latency, etc, but it should work.  200 ms latency is a number I've seen thrown around.  The less latency the better though.
Dennis Mink
please share you desired topology and subnetting.
Please remember to rate useful posts, by clicking on the stars below.
