Time change
jacksonpj51
Some of my agency's phones are moving forward by one hour suddenly .
tgaur
hi,
is this happening after the DST change. try rebooting one phone and see if this make the difference.
regards.
VoIP Engineer
Verify the device pool settings on the phone, and the time settings for the device pool.
Cyril Albert
Maybe you are hitting this defect
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvo26979/?rfs=iqvred
I had the same issue.
Some phone models are concerned (3900, 8900) and some not (8800) when ever you are running CUCM 10 or 11.
Cyril
