How to connect two router with E&M cards
connect101
I have two router : a 3745 with VIC-2E&M and a 1751V with VIC-2E&M.
I want to tranfer call from the 1751V to the 3745 with these cards.
(router )E&M <-> E&M (router)
Is it possible?
How to do? How about connector and pinouts
Thenk you very much.
pcameron
Make sure the router chassis have a common electrical ground connection (very important for E&M) and use a console rollover cable. Refer here for details -
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a0080093f5e.shtml#rollovercable
This will allow you to make calls between the two devices. E&M trunks won't give you supplementary services like transfer/hold/call forward.
Thank you very much.
All your responsee have resolved my issue.
Thank you
Thank you
Thank you
