How to Direct incoming calls to specific phones?
Jason Jenkins
Here is the situation: We have about 200 clients with a variety of phone  numbers. Our help desk is split into 3 teams. Each team takes care of  specific customers. Instead of calling in and having a random person  answer the phone, we want certain customer calls automatically directed  to specific help desk phones. I prefer to do this in the CLI. Can you  give me an idea and sample config of how to configure our CME router to  do this.
Example: When client1 calls in the call should auto direct to team1's three phone extensions. When client2 calls in the call should auto direct to team2's three phone extensions.
One more piece of the config: if either team does not answer the call within 3 rings, the call should roll over to all phone and ring all phones.
Any help you can give is much appreciated.
5 Replies 5
Bruno Rangel
Hi Jason
You can configure Hunt Groups to have this working, look in Configuring Call Coverage Features
Please remember to rate all posts using the stars
Cheers
Bruno Rangel
Cheers
Bruno Rangel
Please remember to rate helpful responses using the star bellow and identify helpful or correct answers
Hunt groups alone won't route based on the calling number, but its a good start for the grouping of agents and also for the other requirement, to ring all phones after 3 rings. For the later put all phones in one hunt group and set that as the last redirect number on the first level of hunt groups.
For the requirement to route incoming calls based on calling number to specific (hunt) groups you can use different set of incoming dial peers that have answer address as the match statement. To route to the hunt group either set a PLAR on the dial peer to the hunt group number or setup a voice translation rule that matches on any called number and translate that to the hunt group number.
Please remember to rate all useful posts.
Response Signature
You might also want to look at this post, https://supportforums.cisco.com/thread/2183294
It's pretty close to what you want to do.
Response Signature
Jason Jenkins
This config is for three fxo phone lines. Each phone line is directed at its own phone extension (2023, 2022, 2021)
For this config each external customer will need to be entered for each phone line and for each phone extension where the call will be forwarded.
If you have hundreds of incoming customer numbers this config when complete could crash your router.
It seems there should be an easier way........
(config)#voice translation-rule 9997
(cfg-translation-rule)# rule 1 /2023/ /2037/
(cfg-translation-rule)# rule 2 /2021/ /2037/
(cfg-translation-rule)# rule 3 /2022/ /2037/
(cfg-translation-rule)# dial-peer voice 8901 pots
(config-dial-peer)# translation-profile incoming test2
(config-dial-peer)# answer-address 5055551234
(config-dial-peer)# port 0/0/0
(config-dial-peer)#dial-peer voice 8902 pots
(config-dial-peer)# port 0/0/1
(config-dial-peer)#dial-peer voice 8903 pots
h(config-dial-peer)# answer-address 5055551234
(config-dial-peer)# port 0/0/2
(config-dial-peer)#voice translation-profile test2
(cfg-translation-profile)# translate calling 9997
(cfg-translation-profile)# translate redirect-called 200
(cfg-translation-profile)#exit
(config)#voice translation-rule 9996
(cfg-translation-rule)# dial-peer voice 8911 pots
(config-dial-peer)# translation-profile incoming test3
(config-dial-peer)# answer-address 5055552345
(config-dial-peer)#dial-peer voice 8912 pots
(config-dial-peer)#dial-peer voice 8913 pots
h(config-dial-peer)# answer-address 5055552345
(config-dial-peer)#voice translation-profile test3
(cfg-translation-profile)# translate calling 9996
(config)#voice translation-rule 9995
(cfg-translation-rule)# rule 1 /2023/ /2040/
(cfg-translation-rule)# rule 2 /2021/ /2040/
(cfg-translation-rule)# rule 3 /2022/ /2040/
(cfg-translation-rule)# dial-peer voice 8921 pots
(config-dial-peer)# translation-profile incoming test5
(config-dial-peer)#dial-peer voice 8922 pots
(config-dial-peer)#dial-peer voice 8923 pots
(config-dial-peer)#voice translation-profile test5
(cfg-translation-profile)# translate calling 9995
(config)#voice translation-rule 9994
(cfg-translation-rule)# dial-peer voice 8931 pots
(config-dial-peer)# translation-profile incoming test6
(config-dial-peer)#dial-peer voice 8932 pots
(config-dial-peer)#dial-peer voice 8933 pots
(config-dial-peer)#voice translation-profile test6
(cfg-translation-profile)# translate calling 9994
paolo bevilacqua
You can use my script "number to name" that supports, among other things, calling number routing for an unlimited amount of numbers.
It can be aquired on the website mentioned in my profile.
