05-04-2012 12:10 AM - edited 03-16-2019 10:58 AM
Hi all,
I'm facing the problem, that our SIP provider is sending the wrong number (registration nr.) in the SIP FROM header.
Check my other discussion:
https://supportforums.cisco.com/message/3586648#3586648
Now I'm trying to copy the SIP To: information to From: with sip profile, but somehow it can't copy it.
Here my setup:
Cisco 2821, c2800nm-adventerprisek9_ivs-mz.151-4.M4.bin, CME Version 8.6
voice call send-alert
voice call convert-discpi-to-prog
voice disc-pi-incoming-on
voice service voip
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
h323
h245 caps mode restricted
sip
asserted-id ppi
voice class uri TRUNK sip
user-id 0815440096
voice class sip-profiles 102
request INVITE sip-header To copy "<sip:(.*)@(.*)>" u01
request INVITE sip-header From modify "<sip:.*@(.*)>" "<sip:\u01@\1>"
voice class sip-copylist 1
sip-header To
voice translation-rule 1
rule 1 // // plan any unknown
voice translation-rule 2
voice translation-rule 40
rule 2 /\(.*\)/ /0\1/
voice translation-rule 190
rule 1 /^0\(.*\)/ /\1/
rule 2 /^9\(.*\)/ /\1/
voice translation-rule 191
rule 1 /297/ /0815440097/
rule 2 /296/ /0815440096/
rule 3 /^0\(.*\)/ /\1/
voice translation-rule 192
rule 2 /^0815440097/ /297/
rule 3 /^0815440096/ /296/
voice translation-profile TP_IN_SIP
translate calling 40
translate called 192
voice translation-profile TP_IN_SIP_1
translate called 1
voice translation-profile TP_OUT_SIP
translate calling 191
translate called 190
! -> INCOMING PEER FROM SIP-PROVIDER to CME
dial-peer voice 2000 voip
description ** SIP TRUNK IN **
b2bua
session protocol sipv2
session target dns:sip12.e-fon.ch
session transport udp
incoming called-number .
incoming uri to TRUNK
voice-class sip profiles 102
voice-class sip copy-list 1
dtmf-relay rtp-nte
codec g711alaw
no vad
! -> INCOMING PEER FROM DIAL-PEER 2000 to PHONE
dial-peer voice 2010 voip
description ** MATCH-URI->changes doing here **
translation-profile incoming TP_OUT_SIP
translation-profile outgoing TP_IN_SIP_1
shutdown
destination-pattern 081544009.
b2bua
session target ipv4:192.168.115.1
dtmf-relay rtp-nte
codec g711alaw
no vad
sip-ua
credentials username 0815440096 password 7 xxxx realm sip21.e-fon.ch
keepalive target dns:sip12.e-fon.ch
authentication username 0815440096 password 7 xxxx
no remote-party-id
retry invite 2
retry response 2
retry bye 2
retry register 2
retry options 1
registrar dns:sip12.e-fon.ch expires 60
sip-server dns:sip12.e-fon.ch
Any ideas? Does the copy function works on the CME or do I need a CUBE?
http://tblog.cisco.be/2011/02/17/cube-conditional-sip-profiles/
Norbert
05-04-2012 12:15 AM
Wouldn't be easier to use a SIP provider that does things right ?
05-04-2012 12:25 AM
You are right, but that provider changed the SIP FROM information as a "security" feature and are not willing to change it back
05-04-2012 01:05 AM
Norbert,
I have l ooked at your other trace and it looks a bit confusing to me..
Can you do another test call...and send only the following debug along with the calling and called number..
Please confirm that you sip provder is 212.55.198.134 and your cme is 192.168.70.240
debug voip ccapi inout
debug ccsip messages
Please remove the other debugs...
