how to figure out ISR4331 E1 slot,bay and subslot number?
baselzind
Level 6
Level 6
the following show inventory come up with this
NAME: "Chassis", DESCR: "Cisco ISR4331 Chassis"
PID: ISR4331/K9 , VID: V04, SN:
NAME: "Power Supply Module 0", DESCR: "250W AC Power Supply for Cisco ISR 4330"
PID: PWR-4330-AC , VID: V02, SN:
NAME: "Fan Tray", DESCR: "Cisco ISR4330 Fan Assembly"
PID: ACS-4330-FANASSY , VID: , SN:
NAME: "module 0", DESCR: "Cisco ISR4331 Built-In NIM controller"
PID: ISR4331/K9 , VID: , SN:
NAME: "NIM subslot 0/1", DESCR: "NIM-1MFT-T1/E1 - T1/E1 Serial Module"
PID: NIM-1MFT-T1/E1 , VID: V05, SN:
NAME: "PVDM subslot 0/4", DESCR: "PVDM4-32 Voice DSP Module"
PID: PVDM4-32 , VID: V02, SN:
im trying to configure the voice gateway from scratch according to this document
https://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/software/feature/guide/vd-t1e1_vwic3.html
but dont knonw how to find the slot , subslot , bay numbers for the E1 card? please help
Ayodeji Okanlawon
It is easier than you think.
In my example, here is my sh inv.
NAME: "NIM subslot 0/1", DESCR: "NIM-4MFT-T1/E1 - T1/E1 Serial Module"
My NIM is on subslot 0/1. This means that each of my E1 port on that module will be numbered as follows depending on how many ports I have ( in my case it is 4)
So it will be e1 0/1/0, 0/1/1, 0/1/2 and 0/1/3
If you do a show diag, you get similar picture
sh diag sub 0/1 ee
SPA EEPROM data for subslot 0/1:
        Product Identifier (PID) : NIM-4MFT-T1/E1
        Version Identifier (VID) : V04
EEPROM data for slot 0 bay 1 daughter board 1
        Product Identifier (PID) : PVDM4-256
        Version Identifier (VID) : V02
Now you define your card type using your slot and subslot number based on the output of your sh inv.    example: ( slot 0/subslot 1 and slot 0/subslot 2)
card type e1 0 1
card type e1 0 2
And finally you can see all my E1 controllers
controller E1 0/1/0
 shutdown
 pri-group timeslots 1-31
controller E1 0/1/1
 shutdown
controller E1 0/1/2
controller E1 0/1/3
 clock source line primary
In your example, you will define your config as follows
card type e1 0 1
and controller e1 0/1/0 ( you only have one port)
Please rate all useful posts
Dennis Mink
your e1 controller is in 0/1 as your output shows.
Please remember to rate useful posts, by clicking on the stars below.
Ayodeji Okanlawon
sh diag sub 0/1 ee
card type e1 0 1
card type e1 0 2
controller E1 0/1/0
 shutdown
controller E1 0/1/1
 shutdown
controller E1 0/1/2
controller E1 0/1/3
card type e1 0 1
