01-09-2008 03:01 AM - edited 03-15-2019 08:07 AM
I have inherited a CME which has the dial-peers configured as such:
dial-peer voice 9567 pots
permission orig
translation-profile incoming Office-incoming
huntstop
incoming called-number 956(7063)?(7064)?(7065)?(7075)?$
direct-inward-dial
port 0/0/0:15
I need to modify the number but haven't a clue how the original setup was done as above with the question mark in the incoming called-number line. Any ideas?
p.s
cme ver: 3.3
ios ver: 12.4(12)
let me know anything I can provide to help with the answer.
thanks in advance
Solved! Go to Solution.
01-09-2008 03:29 AM
To get a question mark in config you need to insert Ctrl^V before the "?".
01-09-2008 03:29 AM
01-09-2008 07:53 AM
Thanks mpillon, it has certainly done the trick.
01-09-2008 04:08 AM
You can also write that pattern in a shorter form:
956(706[345])?(7075)?$
01-09-2008 11:42 AM
Hi, not sure why the low rating for a correct information that was mean to supplement the answer to you question, anyway, good luck.
