IP Telephony and Phones
Labels
I fear there may be a CCM rebuild coming in my near future :).. I'm having a strange problem where I cannot dial internal numbers, that are local to my CCM. Say I have extension 20000, and extension 20001, I cannot dial between the phones. I think...
jkloza by Level 1
  • 443 Views
  • 5 replies
Resolved! DMA Compatibility
Need to confirm if the Data Migration Assistant (DMA) is compatible with Callmanager 4.2(3). The cut-off used to be CM 4.1, but I noticed the Compatibility Matrix now shows it as compatible with 4.1, 4.2 and 4.3. Is this accurate?Thanks in advance.
The bigger picture of what I'm doing is trying to ultimately discern what the cause of my "transfer directly to VM" problems are. Along the way, I've decided to try to understand the debug logs in greater detail. In examining them, I have come acro...
pkluss by Level 1
  • 13899 Views
  • 18 replies
Good day to all!I'm trying to find out if Secure SRST is supported on the Cisco 2821 router. I know that normal SRST is supported and that Secure SRST requires a k9 IOS (that I have in place) however the commands are unrecognised when I type them in....
we have two gks(gk1 and gk2). a 3rd gw is going to setup as remote zone. The idea is call through the 3rd gk to gk1 and gk2 will share the use of gk1 and gk2. What command can achieve?I found the statement:remote zone gk1 7* blast/seqremote zone gk2 ...
