ā07-27-2012 12:49 AM - edited ā03-16-2019 12:24 PM
Hi All,
Let me explain our needs.We have agents who have PC Client(Cisco IP Communicator) or hardClient( CiscoIP Phone which is connected to PC) or both of them. We need to get all InstrumentID of the phones on that PC (Soft and hard phone). I heard something like CDP(Cisco Discovery Protocol) but I have no idea how to use or where to start? Currently, we are just using CTI tookit and it would be great if I can get InstrumentIDs using this toolkit.
I really appreciate any help.
Thank you.
Olcay
ā07-27-2012 02:32 AM
That would reauire quite a bit of programming beyond CTI, recommend you contact an expereinced developer for Cisco UC environments.
ā07-27-2012 03:11 AM
It seems we don't have experienced developer who can help us about CDP right now.May be you can help us Paolo.The only solution which comes to my mind is if I can run "show cdp neighbors details" in SSH session using our desktop application and parse the IP result and compare with the PC IP which desktop application runs on. But we will run our desktop application on many PC and i am not sure the impact of this solution.
On the other hand, i wonder how do you implement your CTI application. All the time, let users to enter instrumentID for their agents.
ā07-27-2012 10:00 AM
Using CDP it can be done as you say. CTI not useful. There are many able programmers if you look around.
ā07-30-2012 02:19 AM
Using wireshark I can see CDP ping packages and get deviceID.But i am not sure how to query InstrumentID using deviceID.Any help on that
ā07-30-2012 04:00 AM
Actually I never heard of "instrument ID" in Cisco nomenclature, you can use the mac-address table to gather MAC address, or HTTP query to get the serial number too.
ā07-30-2012 05:37 AM
Thanks for your support Paolo.
I can use MAC address.Since Softclient uses PC MAC address, I can get softclient MAC address but when i type 'ipconfig all' or 'arp -a' in command prompt on my PC, i can't see MAC address of hardclient.
ā07-30-2012 07:54 AM
As mentioned above, that MAC address is visibile on the switch.
ā07-31-2012 12:59 AM
So MAC address of hardphone which is connected to PC is not visible from PC?
On the switch i can see MAC addresses. But what i need is to see MAC address of IPPhones from the PC.So when an agent wants to login, i will ask whether they want to use softphone or hardphone.Then if user selects hardphone i will get the MAC address and i will use it for login the agent
When i check with wireshark i can see CDP packages are sent and in these CDP packages there are deviceIDs which i actually need.
ā07-31-2012 02:07 AM
Since the phone never sends IP packets to the PC, its MAC address is not visibile to the PC.
ā07-31-2012 02:26 AM
Thanks Paolo.But it is weird, isn't it?.Why I can't reach a deviceID of the phone which is connected to my PC.There should be a way.
Actually we found a solution. But I can't use it since we have user account restricitions.( our uses can't use raw sockets)I hope it will work for someone else.We captured CDP packages using raw socket and get deviceID to log user in.
ā07-31-2012 11:43 PM
Is it possible, Hardphone sends device information to PC and PC keeps it in registry?
ā07-31-2012 11:45 PM
No, the CDP capture option is the typical way.
Aaron
