How to get logs from CUCM for initiated calls
Zaher Juha
Dears,
like in Voice Gateway for initiated calls we can run debugs command like debug voip ccapi inout to know the calling and the called number and the status of the call, matched dial-peer, ... etc
Can we do the same in CUCM
Thanks in advance for your help
CDR is used mainly for call statistics, it is not designed for detailed troubleshooting. Reading cucm logs requires a detailed understanding of how different components function and some practice. It can be a little daunting.
This book is excellent. This is what I always recommend as the starting point..
http://books.google.co.in/books?id=YcCjKsssklIC&pg=PA42&lpg=PA42&dq=call+manager+trace+reading&source=bl&ots=ZW5_hvNFGA&sig=22rtALJZjQFfe9JrHjgAB_GgtRU&hl=en&ei=4qT3TLfTDsuYOs_I3YwI&sa=X&oi=book_result&ct=result&redir_esc=y#v=onepage&q=call%20manager...
This doc explains how to read h323 traces in cucm
https://supportforums.cisco.com/docs/DOC-11779
This blog explains how to understand sip traces..
https://supportforums.cisco.com/document/113271/understanding-sip-traces
Please rate all useful posts
9 Replies 9
Ayodeji Okanlawon
Yes you can. You will need to enable cucm traces and use RTMT to download them You will also need to know how to read the traces..
Here is a link that tells you how to enable and collect traces
https://supportforums.cisco.com/document/126666/collecting-cucm-traces-cucm-862-tac-sr
Thanks Ayodeji
The problem how to read it :)
is there any way just to know the status of the call like in ccapi codes
Gordon Ross
Level 9
Level 9
CDRs will give you a lot of information about calls. They won't give as much as the traces (such as patterns matched, etc) but, in my experience, usually suffice for 98% of troubleshooting.
GTG
Please rate all helpful posts.
Thanks Gordon,
What I need the status of the call like if i have an integration by sip with Avaya without CUBE only buetween CUCM and Avaya PABX just i want to know if the call manager forward the call or not
CDRs will tell you, amongst other things:
  • Calling Number
  • Called Number
  • Answered Number (so when a call is diverted)
  • Duration
  • Device Names
  • IP Addresses
  • etc..
https://supportforums.cisco.com/document/53056/understanding-cdr-call-detail-records
GTG
DEEPSHIKHA JAIN
Hi Ayodeji,
SIP understanding video on cisco community is awesome.
But I was trying to access your blog for sip trace understanding but getting authorization error even after logging into support portal with CCO
Is there any alternate path or location where I go and read this blog?
Hi Deepshikha,
When I click on the link it works. Try it again. I don't have any alternate path for it.
Hi Ayodeji,
That link of yours is not working anymore. Earlier i used to open it and nowadays it's not.
It shows you are no authorized to view this page. I hope if any security setting is not altered.
Regards, Nishant Savalia
