IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6058 Views
  • 14 replies
I am working on a system that has a H.323 gateway and when the caller is on a webex conference the call stops at exactly 1800 everytime they are on the call. I ran debug isdn q921, debug isdn 931, and debug voip ccapi inout. From the the data it seem...
putney_m by Level 1
  • 5992 Views
  • 2 replies
All, on CM 8.6 I have made all the changes needed to have logs going to an external syslog server but the logs are not showing up.  Are there any services I need to restart to put the change in effect?  Thanks.  Replies rated.
Hi voice team,  I will integrate via sip trunk a CUCM 8.6 with Microsoft Lync 2013, it can be configured so that the call with Cisco extension and appear in Lync that someone calling ? or if the person is using the Cisco extension appears in lync as ...
Resolved! License Migration
Hello There,I tried to go through some documents to understand how the licenses from 8.6 to 9.1.2 are calculated but to be honest with you found no answer for my question. Attached are 2 reports from 8.6 and 9.1. As you can see in 8.6 we had 1500 lic...
Hello,in an UCM 10.x environment with 7800 ip phones the user can add up to 99 speed dial destinations in User self portal. But just 6 of these 99 speed dial entries appears on the phone screen if the user press the navigation pad down.Where are the ...
rkrumpe by Level 1
  • 613 Views
  • 5 replies
