How to hard reset cisco 9971 phone
Syed
Level 3
Level 3
Dear All,
IP phone 9971 unregistered all of a sudden, it has ip address, correct tftp, default router ip address, please help me how to hard reset this phone.
Thank you in advance
Rob Huffman
Hi there,
Just in case you ever need this again;
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCua96332
Document alternative factory reset procedure for 8961/9951/9971 phones
CSCua96332
Workaround:
These phones can be factory reset using the following procedure.
Step 1) While powering up the phone, press and hold #.
Step 2) While the mute button is red and the top left and right buttons are amber, type in the key sequence 123456789*0#
Do not power down the phone until it completes the factory reset process, and the main screen appears.
5 Replies 5
Syed
Level 3
Level 3
But this phone is receiving CUCM IP
sorry for typo.
I mean phone is not receiving cucm IP
I have remove the phone and readded.
This is working now...
Rob Huffman
Hi there,
CSCua96332
Workaround:
Thank you so very much for your help...
