How to Remote Control Phones w Coding Scripting
gretchen1983
I have a decent amount of experience in coding and scripting.  What are the ways I can manipulate Cisco IP Phones remotely?  I'd like to do the following things (for example):
  • change Alternate TFTP of a large number of phone (some are remote MRA)
  • control phones, such at dialing test numbers
  • view the phones' screens
Once I get into it I'm sure there will be other valuable things I discover that are possible, like possibly keeping an eye on the Console Logs or watching the MOS score during calls, etc.
I see SingleWire, PhoneView, and UpLinx, and it appears they are doing pretty much what I'd like to do, but I'd prefer to write my own so I have complete flexibility.
What are these apps using to get to the phones?  Are they using the same protocol?  Is it AXL?
Where can I get started on this?  Is there a developer kit?
Thank you!
Jaime Valencia
All the info on API/SDK/etc is in DevNet, that's where you want to start.
java
if this helps, please rate
That link doesn't work:
403 - Forbidden Page or Application
The file or application you are trying to access may require additional entitlement or you are trying to access a file with an invalid name. Additional entitlement levels are granted based on a users relationship with Cisco on a per-application basis.
but I found DevNet here: https://developer.cisco.com/site/devnet/home/index.gsp , except it looks like a huge site.  Does your .../go/pdi  link have an more-specific info?  Thanks Jamie.  It's a start.
Does anyone have any more-specific info to give me some quick traction on connecting to and controlling phones?
That link is in my signature, I never mentioned you'd find any info on what you're looking for in it. You're getting that message because it's a partner level site, if your CCO is not tied to a partner, you cannot access it.
java
Okay, yes, I see.
My office login should work then.
thanks
