02-18-2019 05:24 AM - edited 03-17-2019 02:08 PM
My company is having a problem with users turning down the Speaker volume on the phone(7281) and missing on broadcast announcements. Is there a way to lock the phone speaker volume to max?
The ring volume feature does not affect broadcast announcements. I tested and found that it is the loudspeaker volume that affects announcements. I already found a configuration menu for setting the maximum ring volume. I need to find a way to set the same for speaker volume.
02-18-2019 04:32 PM
02-18-2019 10:32 PM
Thanks @Jonathan Schulenberg
We are using Informacast by Singlewire. I was able to identify the feature on informacast that allows one to set the broadcast volume and it overrides the stream volume setting on phones.
Many Thanks.
