How to set up Call Queuing
carbonscoring
Hi All, I have a couple of users in a line group that I would like to set them up some basic queuing. Is this possible? I have cisco Business edition 6.1.3.2000-1 with cisco unity connection Version 2.1.3ES23.1000-23.
thanks in advance,
Mike
8 Replies 8
Hi Mike,
You can use the attendant console feature of the cucm 6 to make use of its call queueing feature
No need for the unity connection
The Attendant Console built into UC Manager is End of Life and will no longer function starting in 8.0, due out early next year.
Your options are to use a hunt group (native to UCM); or, another product such as Contact Center Express.
But if I'm not wrong, CM hunt-groups do not do call queuing.
Another alternative is B-ACD/AA on the GW in H.323 or SIP mode. That is probably unsupported by cisco.
Attendant console won't be available from version 7 fresh install
But if he upgrade he'll find it after the upgrade to 7
Also you can use the business edition of the attendant console after that
Also you can check the B/ACD solution advised above
Do you know if I can set up basic call queuing with Attendant console and CCM 4.2.3 ?
Andres
Yes, configure broadcast using the acclient.bat to achieve this.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
java
do you have a document for setting up this?
A
Yes, the AC guide as with any version.
Cisco Unified CallManager Attendant Console
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_2_3/ccmfeat/fsccmac.html
ALL CUCM documentation is here, you just need to look for it
http://www.cisco.com/en/US/products/sw/voicesw/ps556/tsd_products_support_series_home.html
Bookmark the above and whenever you need documentation take some time to look in the link.
Or simply search CCO to find the doc.
java
java
