How to setup a 4 port FXO module on 2901
Justin Westover
I need some help getting my 4 port FXO module working on my 2901 router. I realize that I need to use the voice-port command to activate and configure the module but I don't know what port(s) the 4 port FXO modules is using. I performed a sh interfaces and searched through but all I see are my gigabit interfaces, not my FXO module?
13 Replies 13
Roman Rodichev
Level 7
Level 7
show interface doesn't show voice ports
if you do "show run" do you see them in in your configuraiton?
you can do "show voice port summary"
if you can't find them, make sure your router detected the module with "show diag | inc VIC"
I assume you also have DSP modules installed inside the router for the these voice ports?
I believe they are installed, how can I check to make sure? I am pretty new with the voice gateways...
use the commands I posted above
I'm assuming this means that DSP is installed.
Slot 0:
        C2901 Mother board 2GE, integrated VPN and 4W Port adapter, 6 ports
        Port adapter is analyzed
        Port adapter insertion time 16w6d ago
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC14473JL6
        Hardware Revision        : 1.0
        Part Number              : 73-11834-06
        Top Assy. Part Number    : 800-30795-02
        Board Revision           : D0
        Deviation Number         : 113332
        Fab Version              : 03
        Product (FRU) Number     : CISCO2901/K9
        Version Identifier       : V02
        CLEI Code                : CMMBN00ARA
        Processor type           : C1
        Chassis Serial Number    : FTX145103C0
        Chassis MAC Address      : e05f.b943.23d0
        MAC Address block size   : 72
        Manufacturing Test Data  : 00 00 00 00 00 00 00 00
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 34 34 37 33 4A 4C 36 40
          0x10: 06 17 41 01 00 82 49 2E 3A 06 C0 46 03 20 00 78
          0x20: 4B 02 42 44 30 88 00 01 BA B4 02 03 CB 8C 43 49
          0x30: 53 43 4F 32 39 30 31 2F 4B 39 89 56 30 32 20 D9
          0x40: 04 40 C1 CB C2 C6 8A 43 4D 4D 42 4E 30 30 41 52
          0x50: 41 09 C1 C2 8B 46 54 58 31 34 35 31 30 33 43 30
          0x60: C3 06 E0 5F B9 43 23 D0 43 00 48 C4 08 00 00 00
          0x70: 00 00 00 00 00 F3 00 65 40 01 25 41 00 87 42 00
          0x80: 00 F8 00 28 03 E8 1C 89 07 D0 20 21 0B B8 20 93
          0x90: 0F A0 21 2F 13 88 21 83 17 70 21 A8 1B 58 21 B0
          0xA0: 1F 40 21 AB 23 28 21 79 27 10 21 78 41 01 1D 42
          0xB0: 00 00 F8 00 28 03 E8 1C 20 07 D0 1F 40 0B B8 20
          0xC0: 6C 0F A0 21 34 13 88 21 34 17 70 21 98 1B 58 21
          0xD0: 98 1F 40 21 98 23 28 21 34 27 10 21 34 FF FF FF
          0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      PVDM Slot 0:
        64-channel (G.711) Voice/Fax PVDM3 DSP DIMM PVDM daughter card
        Part Number              : 73-11809-03
        Board Revision           : B0
        Deviation Number         : 0
        Fab Version              : 03
        PCB Serial Number        : FOC14492D8S
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM3-64
        Version Identifier       : V01
          0x00: 04 FF 40 05 DB 41 01 00 82 49 2E 21 03 42 42 30
          0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 34 34 39
          0x20: 32 44 38 53 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 8F 50 56 44 4D 33 2D 36 34 20 20 20 20 20 20 20
          0x40: 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 0:
        2 Port FE HWIC
        Hardware Revision        : 2.0
        Top Assy. Part Number    : 800-27738-02
        Part Number              : 73-10677-02
        Board Revision           : B0
        Fab Version              : 02
        PCB Serial Number        : FOC14440GVT
        RMA History              : 00
        Product (FRU) Number     : HWIC-2FE
        CLEI Code                : COUIAFUCAA
        Base MAC Address         : 1cdf.0f89.a7b2
        MAC Address block size   : 2
        Connector Type           : 01
          0x00: 04 FF 40 05 3B 41 02 00 C0 46 03 20 00 6C 5A 02
          0x10: 82 49 29 B5 02 42 42 30 88 00 00 00 00 02 02 C1
          0x20: 8B 46 4F 43 31 34 34 34 30 47 56 54 03 00 81 00
          0x30: 00 00 00 04 00 CB 92 48 57 49 43 2D 32 46 45 20
          0x40: 20 20 20 20 20 20 20 20 20 89 56 30 31 20 D9 02
          0x50: 40 C1 C6 8A 43 4F 55 49 41 46 55 43 41 41 CF 06
          0x60: 1C DF 0F 89 A7 B2 43 00 02 05 01 FF FF FF FF FF
        WIC Slot 1:
        VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1
        Hardware Revision        : 0.0
        Top Assy. Part Number    : 800-22629-05
        Board Revision           : C0
        Fab Version              : 04
        PCB Serial Number        : FOC14473SGD
        RMA History              : 00
        Product (FRU) Number     : VWIC2-2MFT-T1/E1
          0x00: 04 FF 40 03 FC 41 00 00 C0 46 03 20 00 58 65 05
          0x10: 42 43 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
          0x20: 34 34 37 33 53 47 44 03 00 81 00 00 00 00 04 00
          0x30: CB 90 56 57 49 43 32 2D 32 4D 46 54 2D 54 31 2F
          0x40: 45 31 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF
Perhaps I should reboot in order for the FXO card to be recognized?
Do you have VIC2-4FXO or VIC-4FXO? You need VIC2-4FXO to work in 2900. I don't see VIC in your "show diag" output, so I assume you got VIC-4FXO which won't work.
Always refer to this list before buying cards: http://www.cisco.com/en/US/products/ps10537/products_relevant_interfaces_and_modules.html
No, I do have the VIC2-4FXO module, so I know I have the right on at least. That's why I was saying that perhaps I just need to reboot the router in order for it to be recognized?
Yes, perhaps. Those slots are not OIR by the way, you must turn off the box before adding/removing cards.
Alright, then that is why I don't see them in my config.
So once I see the slots, I am trying to setup our Voice gateway to take 911 calls and send them out those POTs lines instead of over the WAN to our CUCM. Any recommendations there? Do I even need to setup a gateway in CUCM since this isn't going to be for SRST call fallover, just 911 local dialing? Sounds like I just create the dial peers and setup the voice-port right?
You will need to set up this 2901 as a voice gateway in CallManager if you want IP Phones in that site to use this gateway for any calling through FXO ports.
The easiest will be to set it up as an MGCP gateway. You will then see four FXO ports in the callmanager and can setup your route patterns, route lists, route groups to point to them. There's more to it of course. In this case, you will not have any dial-peer voice commands on the voice gateway. Dial-peer voice commands are necessary if you set up the gateway as H.323  or SIP and if you need failover to SRST.
This should help.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008017825e.shtml
It's for older Callmanagers, but the configuration is very very similar.
Alright so I know how to create the gateway in CUCM and also the route group along with route route patterns. All of our current gateways are h323 and I would like to stick with that. What would I need to do on the voice gateway once I have configured those things on the call manager?
here's an example. it's as simple as it gets.
voice class h323 1
h225 timeout tcp establish 3
interface GigabitEthernet0/0
ip address 10.0.0.1 255.255.255.0
h323-gateway voip interface
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
dial-peer voice 100 pots
preference 1
destination-pattern 911
prefix 911
port 0/2/0
dial-peer voice 101 pots
preference 2
prefix 911
port 0/2/1
dial-peer voice 102 pots
preference 3
prefix 911
port 0/2/2
dial-peer voice 103 pots
preference 4
prefix 911
port 0/2/3
dial-peer voice 1000 voip
voice-class h323 1
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
qtssyd1-cvg001-syd4#show diag | b VIC
Product (FRU) Number : VIC3-4FXS/DID
Version Identifier : V03
CLEI Code : IPUIA6JRAC
