03-15-2015 10:45 PM - edited 03-17-2019 02:19 AM
03-15-2015 10:56 PM
Can you provide the exact CUCM Versions , from which you are upgrading and to which you want to upgrade .
Also, can you be a little more specific on what kind of information are you looking for ?
Aditya Gupta
03-15-2015 11:29 PM
In addition to what Aditya has asked, u can opt for PCD[Prime Collaboration Deployment] for doing the upgrade.
Need to have valid UCSS/ESW contract for ordering through PUT[Product Upgrade Tool]
regds,
aman
03-16-2015 09:58 AM
Please check the details ,
Hardware and Software details of Call Manager and Unity are required
Hardware Version:
Platform Type | 7816I3 |
Serial Number | KQPANXZ |
Processor Speed | 3200 |
CPU Type | Intel(R) Celeron(R) D CPU 3.20GHz |
Memory | 2048 Mbytes |
Object ID | 1.3.6.1.4.1.9.1.898 |
OS Version | operatingsystem.UCOS4.0.0.0-9 |
RAID Details | RAID not configured |
Software Version:
Active Version | 7.0.2.20000-5 |
Licenses:
Phone License Feature
License Server | Units Authorized | Units Used | Units Remaining | Units Pending |
192.168.1.31 | 322 | 317 | 5 | 0 |
Total Units for Feature | 322 | 317 | 5 | 0 |
CCM Node License Feature
192.168.1.31 | 2 | 1 | 1 |
Total Units for Feature | 2 | 1 | 1 |
Software License Version
License Server | SW Version |
192.168.1.31 | 7.0 |
2- Number of IP phones currently in use and their model details are required
Models of IP Phones:
7936
7960
7912
7911
7940
7942
Number of IP Phones:
84
3- Existing Voice Gateway model details are required and which PSTN lines are in use FXO or PRI?
VOICE GATEWAY DOES NOT NEED TO BE CHANGED
4- Which signaling protocol is used for communicating with gateways H323 or MGCP? I DON’T KNOW ABOUT THIS
5- Are there any remote sites where IPT is used or is it a single site only? NO, IT IS A SINGLE SITE
6- Are there any third-party applications integrated with Call Manager (e.g. Fax, Billing, Recording)? NO
7- Existing configuration needs to be migrated to the new system or not? YES
8- Which NTP device is used on the network? DOMAIN CONTROLLER SERVER
9- Is there any integration of Call Manager with Active Directory? NO
10- Are there any issues which exist in the current system? If yes, please provide details. YES IT HAS REACHED END OF SUPPORT LIFE, CISCO WILL NOT SUPPORT IT ANYMORE. IP PHONE G7912 KEEPS DISCONNECTING.
03-16-2015 05:24 PM
You basically have two options
A) PCD
B) Jump upgrade, then upgrade to 10.x
If that 7816 has a 5K, then forget about the above, your options then would be
A) BAT for CUCM
B) Cobras for CUC
And you need to mention EXACTLY what assistance you need.
Have you already reviewed the upgrade guides and RNs of 10.x??? If not, that would be one of the first steps
03-16-2015 08:00 AM
Hi,shijingk87.
Can you tell me more about the upgrade? What are you trying to achieved?
Please feel free to PM me if you need further assistance.
Thanks!
