Howe do i change phone numbers on all phones in a device pool ?
Rune Larsen
We have to change the phone numbers on all phones in a device pool. We have a did range today start with 3228xxxx. This have to be changed to 3270xxxx. Is there a quick way to do this?
Hi Aman
The instructions are in the thread I referenced. It's a CLI app, not a gui/windows app.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
6 Replies 6
Aaron Harrison
Hi Rune
See this thread for my little tool to do this based on an input CSV: https://supportforums.cisco.com/thread/2119442
Aaron
Please rate if useful....
Hi Aaron,
I was just going through the thread and I downloaded the attachment ExtensionRemapDN.zip.But when I click it after unzipping it , black screen opens and closes.
If u could explain the steps on how to get info from call manager and then, run , it would be helpful.
regds,
aman
Hi Aman
Aaron
Thanks, This is a greate tool. I have tested i and it worked fine.
Rune
Hi Rune
Glad to hear it.
Please remember to mark questions as 'answered' to help identify useful responses.
Aaron
Hi Rune.
To add an option to the great tool that Aaron suggested (+5 P A) you can use BAT exporting all phone detail, modify just DN and use again BAT to update phones with modified info.
After this operation, just remember to delete old unassigned numbers.
Carlo
Please rate all helpful posts "The more you help the more you learn"
