HTTP Authentication Digest for SIP messages in a trunk SIP CUCME
antonio.guirado
Level 3
Level 3
we would like to implement HTTP Authentication Digest for SIP messages in a trunk SIP between a Cisco 2851 and an Asterisk server.
We are using CUCM Express with 15.1(4)M (CME 8.6) as voice gateway to connect to PSTN.
According to Cisco documentation:
"To configure a gateway to use HTTP Authentication Digest, give the following command in each dial peer or SIP-UA configuration mode:
authentication username username password password [realm realm]."
The problem is that when call is from CISCO to ASTERISK, Asterisk sends a challenge to Cisco to do Authentication:
INVITE sip:968277830@10.1.32.70:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.70.11:5060;branch=z9hG4bK3E205D
Remote-Party-ID: "DN1001" <sip:1001@10.0.70.11>;party=calling;screen=no;privacy=off
From: "DN1001" <sip:1001@10.0.70.11>;tag=5317D4-2271
To: <sip:968277830@10.1.32.70>
Date: Thu, 20 Feb 2014 10:55:56 GMT
Call-ID: 6890E69B-995411E3-808DE206-4D0B76AC@10.0.70.11
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 1679566433-2572423651-2156454406-1292596908
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1392893756
Contact: <sip:1001@10.0.70.11:5060>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 208
<--- Reliably Transmitting (no NAT) to 10.0.70.11:5060 --->
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 10.0.70.11:5060;branch=z9hG4bK3E205D;received=10.0.70.11
To: <sip:968277830@10.1.32.70>;tag=as665c9410
CSeq: 101 INVITE
Server: Asterisk PBX 11.7.0
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH
Supported: replaces, timer
WWW-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="559bd1d2"
Content-Length: 0
However, when call is for ASTERISK to Cisco, there is no challenge sent.
INVITE sip:1001@10.0.70.11 SIP/2.0
Via: SIP/2.0/UDP 10.1.32.70:5060;branch=z9hG4bK0c57d67c
Max-Forwards: 70
From: "JOSE MANUEL" <sip:968277447@10.1.32.70>;tag=as2f789a9f
To: <sip:1001@10.0.70.11>
Contact: <sip:968277447@10.1.32.70:5060>
Call-ID: 3a0729962d702b4056b6f9821f14917e@10.1.32.70:5060
CSeq: 102 INVITE
User-Agent: Asterisk PBX 11.7.0
Date: Thu, 20 Feb 2014 09:58:27 GMT
Content-Length: 282
<--- SIP read from UDP:10.0.70.11:60829 --->
SIP/2.0 100 Trying
Date: Thu, 20 Feb 2014 10:58:27 GMT
CSeq: 102 INVITE
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
SIP/2.0 180 Ringing
To: <sip:1001@10.0.70.11>;tag=556830-757
CSeq: 102 INVITE
Remote-Party-ID: "DN1001" <sip:1001@10.0.70.11>;party=called;screen=no;privacy=off
Content-Length: 0
My configuration in Cisco device is:
dial-peer voice 1 voip
description **Calls to ASTERISK **
destination-pattern 9T
session protocol sipv2
session target sip-server
codec g711ulaw
sip-ua
keepalive target ipv4:10.1.32.70
authentication username CCME password 7 070E234F4A realm asterisk
  sip-server ipv4:10.1.32.70:5060
To avoid that the ASTERISK is blocked by Cisco TOLLFRAUD_APP I have added:
voice service voip
ip address trusted list
  ipv4 10.1.32.70 255.255.255.255
allow-connections sip to sip
sip
  registrar server
The issue is that I would like that Cisco also send a challenge to asterisk server to authenticate SIP messages.
Any ideas?.
Regards.
Dragan Ilic
Level 4
Level 4
Did you try with "credentials username..." command under sip-ua config? with adequate parameters which coresponds to your environment in this command...
HTH,
Dragan
HTH,
Dragan
yes, but credentials command configure credentials that are used when Cisco UA must register in a server.
I do not need register Cisco into Asterisk server. What I want is that Cisco authenticate SIP messages that receive. I know
that can be enough with TOLLFRAUD_AP where remote IP is checked, but I want to do something like others routing
protocols (as OSPF, BGP) where every message must be authenticated.
Thanks.
Regards.
