09-06-2012 07:42 AM - edited 03-16-2019 01:04 PM
I have setup a hunt group with two numbers. When I call the hunt pilot number the first extension rings but then when the Reversion Timeout (set in the Line Group) expires I get a busy tone instead of it ringing the other number. I have tried re-creating the hunt group, resetting all the resettable devices including handsets and changing the pilot number. I have also tried different settings in the Line Group configuration for distribution algorithm and hunt options - all to no avail.
I hope someone can shed some light on this for me.
09-06-2012 08:14 AM
What happens when you set the algorithm to Broadcast? Do both phones ring at the same time?
Chris
09-06-2012 08:23 AM
The lines in the group are shared - I suspect because I am using extention mobility. As far as I am aware you cannot use the Broadcast algorythm with shared lines.
09-10-2012 12:34 AM
We have decided to look at this another way and to hold the hunt group plan for now. I'll revisit this later on. Thanks for the comment Chris.
