Hunt group forward no answer not hitting correct voicemail
cnoonan
I have a DN (879019) which is set to CFA to voicemail.
When this number is dialled directly by a phone the mailbox message is heard and a voicemail can be left.
This number has been configured as the Hunt Pilot Forward-No-Answer DN and its partition is contained in the CSS assigned.
When the Hunt Pilot times out it forwards the call and but is the Unity Connection system greeting that is heard and not the DN's personal greeting. This is the same behaviour as when a voicemail box does not exist for a particular user.
Any help will be much appreciated as I am supposed to put the system live at the weekend.
thanks
Chris
Jaime Valencia
Because CUC receives the original called number, which is the one from the hunt pilot.
You can configure that as an alternate DN for the mailbox, configure call routing rules in CUC, or create a VM profile which hardcodes that DN. either will work
java
if this helps, please rate
cnoonan
Sorry I forgot to say, both UCM and CUC are version 8.6.2.22900-9
Jaime Valencia
java
cnoonan
Thanks Jaime that worked a treat.
