cisco attendant console enterprise 8.6 compatibility
testspa
Hi all,
is the attendant console enterprise 8.6 compatible with the CUCM 9.1?
I found some compatibility matrix but they aren't very clear.
Thank you very much, regards
Dwe
Rob Huffman
Hi Dwe,
I don't believe 8.6 is supported but 9.0 is
Product Specifications
Cisco  Unified Attendant Console Enterprise Edition Version 9.0 is supported  on Cisco Unified Communications Manager Versions 8.0(1) through 9.1(1).  Cisco Unified Communications Manager Express is not supported. For Cisco  Unified Communications Manager Version 7.1(5) support, please use Cisco  Unified Attendant Console Enterprise Edition Version 8.6.2.
From;
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps7046/ps7282/data_sheet_c78-520987.html
and;
Software Compatibility
Cisco Unified
Enterprise Attendant
Console Version - 8.6.2.11
Cisco Unified Communication Manager Ver si o n
7.1(5)
8.0(1)
8.0(2C)
8.5(1.1)
8.5(1)
8.6(1.3)
8.6(1)
8.6(2.2)
8.6(2)
From;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmac/arc/CUEAC_Rel_Note8_6_2_11.pdf
Cheers!
Rob
"Hours are like diamonds, don't let them waste
Time waits for no one, no favors has he"
- Stones
Thank you very much Rob and Chris!
Dwe
