Hunt group
jcconde01
I need to have a phone ring three times when you call and if no answer then go to a broadcast group. Can I do This?
There are 8 members on this group. The first time you call a member of this will need to have the same configuration.
George Sotiropoulos
Yes, this is possible. Please use the following guidelines:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/8_5_1/ccmcfg/bccm-851-cm/b03lngrp.html
Hope this helps, let me know if you need additional info.
G
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
George Sotiropoulos
G
Thanks for your help
Nadav
Level 7
Level 7
Take a gander over here:
https://community.cisco.com/t5/ip-telephony-and-phones/change-after-3-ring-forward/td-p/1856104
and then use Call Answer No Forward for the line to forward it to the hunt pilot.
