11-26-2018 12:04 PM - edited 03-17-2019 01:46 PM
I need to have a phone ring three times when you call and if no answer then go to a broadcast group. Can I do This?
There are 8 members on this group. The first time you call a member of this will need to have the same configuration.
Solved! Go to Solution.
11-26-2018 12:34 PM
Yes, this is possible. Please use the following guidelines:
Hope this helps, let me know if you need additional info.
G
11-26-2018 12:34 PM
G
11-26-2018 05:21 PM
Thanks for your help
11-26-2018 12:40 PM
Take a gander over here:
https://community.cisco.com/t5/ip-telephony-and-phones/change-after-3-ring-forward/td-p/1856104
and then use Call Answer No Forward for the line to forward it to the hunt pilot.
