07-15-2015 05:29 AM - edited 03-17-2019 03:39 AM
Have 6 phones in a group. Can I get all the phones to ring at the same time ?
VR
07-15-2015 06:03 AM
You did not specify your phone system, assuming CUCM setup the line group as Broadcast hunting.
If CME then you use parallel hunting.
07-15-2015 06:23 AM
Hi VR,
If it is a plain straight forward case of making sure all phones ring at the same time, then you may also use Shared Line Appearance as well.
07-15-2015 12:48 PM
best way would be use broadcast hunting in line group
