HW Requirements for CUCM
andreac81_
I need to install CUCM to serve 3.500 users, is it possible to install it on a server IBM x3650 2 quad core, 4GB RAM, 73GB HD, 4 ethernet?
Rob Huffman
Hi Andrea,
You will need to identify what CUCM version you are going to build
as a first step. Then move forward with picking a server model
This is the "master" list for Server support.
Supported Cisco Unified Communications Manager Releases by Server
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
Hope this helps!
Rob
Rob Huffman
Hi Andrea,
Hope this helps!
Rob
I'll propose CUCM 8.0, I found all informations in your link.
Thanks.
