09-29-2014 11:17 AM - edited 03-17-2019 12:19 AM
we are running several CME installations on 29xx routers connected to a E1 and T1 PRIs in different countries. In the past we always used the HWIC-1CE1T1-PRI adapter and never ran into bigger problems.
This time we are trying to connect a 2951 router using a VWIC3-1MFT-T1/E1 to an E1 PRI in Switzerland, and its not working. Before I dig deeper into it just one question: Is the VWIC3-1MFT-T1/E1 in general capable of the same features as the HWIC-1CE1T1-PRI or could it be that this card is just the wrong one for an E1 PRI (there is also a G703-Variant which i may need?)?
Configuration:
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn overlap-receiving
isdn incoming-voice voice
isdn send-alerting
isdn bchan-number-order ascending
isdn sending-complete
no cdp enable
voice-port 0/0/0:15
cptone CH
Some diag output:
router#sho controller e1
E1 0/0/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info FPGA Rev: 08121917, FPGA Type: PRK1
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
International Bit: 1, National Bits: 11111
Data in current interval (890 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
2 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
2 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
router#sho isdn status
Global ISDN Switchtype = primary-net5
ISDN Serial0/0/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0xFFFF7FFF
Number of L2 Discards = 0, L2 Session ID = 133
Total Allocated ISDN CCBs = 0
Debug while trying an outbound call (numbers obfuscated):
router#
003426: Sep 29 20:14:00.922 CEST: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 8998316941
003427: Sep 29 20:14:00.922 CEST: ISDN Se0/0/0:15 Q931: Sending SETUP callref = 0x0084 callID = 0x8005 switch = primary-net5 interface = User
003428: Sep 29 20:14:00.922 CEST: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0084
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Progress Ind i = 0x8183 - Origination address is non-ISDN
fti-zrh01-pbx01#
Calling Party Number i = 0x0180, '8998316941'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '00491751234567'
003430: Sep 29 20:14:08.922 CEST: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0084
Cause i = 0x80E6 - Recovery on timer expiry
003431: Sep 29 20:14:08.922 CEST: ISDN Se0/0/0:15 **ERROR**: CCPCC_CallOrigination: SETUP timed-out (2nd T303) to NETWORK. The SETUP failed.
Solved! Go to Solution.
09-29-2014 12:13 PM
I just compared this to my Switzerland config using VWIC3-MFT card and all is the same, except I am using default framing.
Chris
09-29-2014 12:13 PM
Chris
09-29-2014 12:26 PM
Thanks Chris - it was the framing, now it´s working!
