05-22-2012 07:52 AM - edited 03-16-2019 11:17 AM
I need to configure h323 output groups. Ie, for a user groups need to go through a FX0 (1) and another different groups of users occupying FX0 other door (2). How I can do this?
Solved! Go to Solution.
05-22-2012 09:44 AM
I usually just configure route patterns with a prefix, on the GW configure the POTS DPs with that prefix and since it's going to be an exact match it will be stripped and you'll only send the original digits out.
ie route pattern 5XXX, prefix 152
destination-pattern 152XXXX
port 0/0
route pattern 5XXX, prefix 151
destination-pattern 151XXXX
port 0/1
Just adjusts CSS and partitions so that the users reach the right route pattern which will prefix the right digits depending on what FXO you want to use.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
05-22-2012 08:39 AM
You always need to mention what product you're using (CUCM, CME, UC520, etc and version) and not just what you're trying to do.
java
05-22-2012 09:33 AM
Sorry. I'm using CUCM 7.1.5. Thanks
05-22-2012 09:44 AM
port 0/0
port 0/1
java
05-22-2012 08:41 AM
You'll need to use cor-lists, you can find plenty of good examples here and on Cisco pages.
HTH,
Chris
05-22-2012 09:46 AM
No need to place restrictions. Just assign a resource (FXO) to a group of users and other resources (other different FXO) to other specific users. Both outputs (FXO) have the same privileges.
