I need to remove the "a=crypto:" part from my SDP header to my ISP (cannot move it so I am opening a discussion in security section)
SDP header from PureCloud via TLS
Content-Type: application/sdp
User-Agent: ININ-EDGE/1.0.0.9458
Content-Length: 351
v=0
o=- 2580238779 3812407684 IN IP4 172.24.22.90
s=-
c=IN IP4 172.24.22.90
t=0 0
m=audio 21970 RTP/SAVP 8 0 101
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=crypto:1 AES_CM_128_HMAC_SHA1_80 inline:KF2wFSwIE66sdkLz+xXOrcI6EWCJe6YkIdHBLrbh
a=crypto:2 AES_CM_128_HMAC_SHA1_32 inline:pII/UErAVu99wbWSL/EjlLjhdmV2pFgKFIrV4j4D
a=sendrecv
I apply the following SIP manipulation rule on the outbound dial peer to the ISP
request ANY sdp-header Audio-Attribute modify "(a=crypto:.*inline:[A-Za-z0-9+/=]+)" ""
Then it removes the a=crypto but leaves to blank spaces between a=fmtp and a=sendrecv (I just filled it in with the words blank spaces but in the debug it is 2 blank spaces then the a=sendrecv part)
Content-Disposition: session;handling=required
Content-Length: 184
v=0
o=- 2580238779 3812407684 IN IP4 10.80.14.230
s=-
c=IN IP4 10.80.14.230
t=0 0
m=audio 12392 RTP/SAVP 8 0 101
a=fmtp:101 0-15
(blank space)
(blank space)
a=sendrecv
if I change the modify to remove
request ANY sdp-header Audio-Attribute remove "(a=crypto:.*inline:[A-Za-z0-9+/=]+)"
all a= values gets removed.
Content-Length: 184
v=0
s=-
t=0 0
How can I get rid of just the a=crypto part in my SDP header to my ISP as they do not allow or accept it.
I have tested this numerous ways on https://cway.cisco.com/tools/SipProfileTest/ SIP-Profile Test Tool
I have also tried with:
request INVITE sdp-header Audio-Attribute modify "(a=crypto:.*inline:[A-Za-z0-9+/=]+)" ""
equest INVITE sdp-header Audio-Attribute remove "(a=crypto:.*inline:[A-Za-z0-9+/=]+)" ""
same result
Best Regards
Issue was resolved by adding and removing the following commands:
voice service voip
no srtp fallback
dial-peer voice xx voip (incoming from PureCloud)
srtp fallback
dial-peer voice XX voip (outgoing to ITSP it was UDP but just to make sure added the below)
session transport udp
sip-ua
connection-reuse
Best Regards
To answer myself, the cube should automatically do interworking between rtp and srtp as the ISP dial-peer is set to UDP and the CC dial-peer is TLS, but for some reason my CUBE keeps on sending crypto to the ISP over the UDP dial-peer.
Best Regards
voice service voip
no srtp fallback
srtp fallback
sip-ua
connection-reuse
Best Regards
