IM&P and CUCM mismatch installation issue
Matt_W
Level 3
Level 3
I have CUCM version 12.5 up and running and then went back to install IM&P.  The issue is I only have 12.0 bootable media for IM&P.  So after going through the setup process, I get the error "Configuration validation with cucm (IP address) failed.  Configured version 12.0.1.10000-12 does not match the version at (ip address)."
I can't seem to find a way to upgrade the IM&P bootable media before/during installation.
Any ideas?
Anthony Holloway
All IM&P ISOs are bootable. Just download the 12.5 version you need from here:
https://software.cisco.com/download/home/286322282/type/282074312/release/12.5(1)SU1
Anthony Holloway
Thank you! it said non-bootable in the description, but I was able to use it anyway.  The fist time I booted with it it gave me en error but I just shut down the VM and rebooted with the same iso and it worked the second time.
