02-04-2021 01:46 PM - edited 02-04-2021 01:47 PM
I'm getting UC_ICSA-2-InterClusterSyncAgentSyncFailure errors between two IM&P clusters' publishers.
I looked up the error and the "fix" says the sync agent will try again every 5 minutes.
Does anyone know how to fix this? Cisco TAC could not provide any answers.
02-05-2021 04:42 PM
As per the error details, the recommended action says it will try resyncing every 5 minutes. Are you facing any connectivity issues between servers? How is it impacting to the end users?
Error Message
%UC_ICSA-2-InterClusterSyncAgentSyncFailure: %[remotePeerAddress=String][AppID=String][ClusterID=String][NodeID=String]: Cisco Intercluster Sync Agent service detected periodic sync failure
Explanation Cisco Intercluster Sync Agent service detected an exception.
Recommended Action Cisco Intercluster Sync Agent service will try resyncing every 5 minutes.
You may try enabling Auto Recovery for Intercluster Peer Periodic Syncing Failure service parameter.
02-08-2021 08:49 AM
Thank you. I will try this.
