IMAGICAL BILLY BLUS
omarahmed
Hello all
 i need to integrate CUCM with IMAGICAL BILLY BLUS to do billing could you please let me know how I can do it or if you have document, please share it.
From cucm, You need to add the Imagicle on cdr management page so that cucm will dump  cdr on Imagicle server.
Go through the guide.. complete configuration are well explained on that guide.
I started deploying Imagicle following the guide I shared above
Response Signature
Follow the KB guide it has all required information step by step  to complete the configuration
https://www.imagicle.com/en/resources/knowledge-base-results/kb/installation-and-configuration_681.html
Response Signature
omarahmed
ok what I need to do from cucm side to integrated with IMAGICAL BILLY BLUS what the Stup required what the required configuration
Response Signature
khorram1998
If "IMAGICAL BILLY BLUS" is a billing software that you would like to integrate with Cisco Unified Communications Manager (CUCM), the process will likely involve creating a custom integration between the two systems. This would typically involve using APIs or other integration methods provided by both CUCM and IMAGICAL BILLY BLUS, in order to transfer call data and other information between the two systems.
I recommend checking the documentation of the IMAGICAL BILLY BLUS and the CUCM in order to see if there is any integration guide provided. If not, you may want to reach out to the vendor of IMAGICAL BILLY BLUS to see if they can provide any guidance or support for integrating with CUCM.
Here is the documentation Link for Imagicle Billy Blues:
https://kbp.imagicle.com/kb/afile/138/61/
Alternatively, you can seek the help of a professional services provider that has experience in integrating CUCM with other billing systems.
Please let me know if you have any more information about IMAGICAL BILLY BLUS, so I can assist you better.
All the best,
AK
