Bookmark
Subscribe
411
Implementing CUBE on non edge router
actualabhishek
I am planning to implement CUBE on CME voice gateway and this gateway is the non edge device in our network with 2 gig Ethernet connection to access switch and Core switch.
Any traffic to internet will flow from CME gateway (CUBE)--->Core Switch---->WAN Internet Router---->Level 3 MPLS cloud (Internet)
Is it possible to configure CME as a CUBE without having any direct link to internet, so that we can route calls to SIP ITSP?
Thanks!!
2 Accepted Solutions
Vivek Batra
I don't see any issue in this as long as CUBE has a connectivity to ITSP either direct or indirect.
- Vivek
It is possible. All you need is an IP connectivity between ITSP and CUBE. However, this isn't the best practice. CUBE usually should be at the edge of the network
Vivek Batra
- Vivek
